It is currently Fri Mar 29, 2024 4:39 pm
 Page 1 of 1 [ 8 posts ]
 Post subject: Diaphragms
PostPosted: Sat Oct 04, 2008 3:28 am
Hi guys
Looks like I have troubless with my avac. When I rev the engine diaphragms moves up and stay up. I know that they shoul move up when rev and move down when on idlle. But mine want move down. Iw tryed test diaphragms with mouth and they work well. iw tryed to disconect line wich is going from electro valve to diaphragmas and car goes bad at low rpm but from 5000-7000 goes sick, when I conect everyting like it should be car goes well from 3000-5000 but after is dead. When I disconect conector which is going from ecu to electro valve car goes well only from 5000-7000rpm .
Here is vid how they should work http://smg.photobucket.com/albums/v214/ ... _A0015.flv
here is a pic how it looks like conected http://img150.imageshack.us/img150/4208 ... 197ek3.jpg
Does anyone know what is problem
TNX a lot
PostPosted: Sat Oct 04, 2008 1:24 pm
So when you rev they move, and when it falls to idle they wont move back?
BTW both your links dont work.
PostPosted: Sat Oct 04, 2008 2:24 pm
links repaired,yep here is video
PostPosted: Sat Oct 04, 2008 8:32 pm
I think the vacuumhoses at the electric solenoid aren't installed correctly. So switch those 2 hoses and check.
PostPosted: Sun Oct 05, 2008 4:46 pm
tnx a lot man that was problem 8) :D
 Post subject: Re:
PostPosted: Wed Jun 23, 2010 12:25 am
If i rev the engine the diaphragms will moves up and down normally. Is the ACAV systeme ok?? Anything else to check?
sotoszx
 Post subject: Re: Diaphragms
PostPosted: Wed Jun 23, 2010 10:34 pm
They should move again @ 5k RPM.
PostPosted: Thu Jun 24, 2010 2:33 pm
Thanks you, i will check it
sotoszx
