It is currently Thu Mar 28, 2024 1:20 pm
 Page 7 of 7 [ 96 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: Zx 16v 167 from The Netherlands.
PostPosted: Mon Feb 04, 2013 9:50 pm
Are you planning on running E85? as those are EPIC injectors!
Re-catcams pulleys, before installing them check them on a lathe, I have seen several that did not run straight and needed the hub section making flat, heard of 0.5mm runout on some!
easy to rectify but really should not happen.
PostPosted: Thu Feb 07, 2013 11:18 am
I am stil not sure about the E85. But the tuner had good experience with those injectors on the RFS engine. So i hoop he is right.
About the Catcam pulleys i will check them confused
Thank you!
PostPosted: Mon Feb 11, 2013 12:42 pm
More pictures :twisted:
PostPosted: Tue Feb 12, 2013 2:22 pm
looks good! wink
PostPosted: Fri Feb 15, 2013 8:21 am
Thanks
PostPosted: Fri Feb 15, 2013 7:21 pm
Awesome work .
Users browsing this forum: No registered users and 10 guests
