It is currently Sat Apr 20, 2024 1:58 pm
ZX-1993
Post subject: Dash gauges fuse rating Posted: Sat Oct 03, 2009 2:09 am |
Joined: Sat Dec 08, 2007 2:33 pm Posts: 43 Location: Southampton, UK
The fuse that is on the Fuel gauge, Rev counter, dash lights, oil press, oil temp etc keeps on blowing. Does anyone know the rating of this fuse? is it 5 or 10 amp? can someone check for me please? Does anyone know why this would blow for?
Post subject: Re: Dash gauges fuse rating Posted: Tue Nov 03, 2009 10:39 pm |
As far as I recall it is 10amp. There are many possibilities why it would blow. One good probability could be a engineloom wire which lost it's insulation. The sensor for the watertemp gauge wires could short if there is a fault in the loom and blow the fuse...
ZX-1993
Post subject: Re: Dash gauges fuse rating Posted: Sun Nov 27, 2011 9:19 pm |
Well I didn't realise this before, but it was blowing every time I put it into reverse. I did find I had one reversing lamp bulb blown, so I've changed that and cleaned all connectors to do with the reversing light bulbs. Seems to have cured it
