It is currently Fri May 09, 2025 3:41 pm
 Page 5 of 6 [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Aug 22, 2007 8:59 pm
yes thats true u car must of bin quite loud with no centre box befor.i was just saying before aint peformance cat-converters expensive. :D
PostPosted: Fri Oct 19, 2007 7:42 pm
hello team leader the king of the forum lol.wats new with the zx machine any mre ideas tricks up ur sleeeve or u looking for that one great idea aghhhh i u just get it yeah noo.well thats were i am at the mo.will look forward to ur next up dated
PostPosted: Sat Oct 20, 2007 10:00 pm
No major plans ;)
Just keep it rolling, dents and paint damage will be fixed sometime in the future. Also a TCT conversion will happen.... someday :D
Today I've been working on my righthand driveshaft, after a trackday in Belgium, it failed on the way back home. Car vibrated like crazy with the slightest acceleration :shock: I had already replaced the righthand shaft 2 years/25.000Km ago, so I thought it would be the other short one.
But it wasn't. This axle was a overhauled one from Citroen. I'll never buy one of those again.
On the bench
Metallic grease? Or small pieces of iron??
Hmm lost some bearing rods!
Not good!
Broken parts, even a broken bearing rod!
The surfaces have been damaged by the broken bearing, and also there's some play of the whole thing on the axle, so it it'll have to be replaced.
Also damaged
PostPosted: Wed Dec 12, 2007 7:21 pm
whyd u get all the messy jobs hahahah.well ur getting all the parts all sorted so ur good fora couple more years.the fuel tank bit looked like a fun job lol :D
PostPosted: Wed Dec 12, 2007 7:56 pm
It was ;)
PostPosted: Mon Jan 14, 2008 6:45 pm
just noticed while i was going through ur pages.u got ride of ur keypad imobliser.was that tricky or did u hide it sumwere else.alsowats the wee filter attach to in ur engine bay.any benifits from that
PostPosted: Mon Jan 14, 2008 9:23 pm
It's hidden behind center console. You can take it off, start the engine and just pull out the keypad connector :)
Refit: start the engine en refit connector.
I still have it cause if u pull it out, it'll also disable the ECU warning light, which sometimes comes in handy.
PostPosted: Wed May 07, 2008 9:52 pm
New projects 8)
LED conversion rear lights:
Creating a design
leds test ;)
Testing
Brake!
Clusters back in the ZX
Just brake:
Just dipped beam:
Both:
Indicator:
Reverse:
Heater matrix was creating some unwanted coolant smell so it was dying, time to replace it, for that the whole dash needs to be taken out. A good moment to fix wiring neatly, replace the alarm and some other stuff that's use when the dash is out.
Heater is out, AC unit is on the right and does not need to be disconnected, which I feared because it's still an R12 filled system which cant be filled anymore, you'd need to modify it to R134a when it's not working anymore or when it's empty.
The idle intake had it's own filter, but is was too small so now it will breathe through the 'big' air intake.
PostPosted: Tue May 27, 2008 9:38 pm
lots of fun solderin them lights up.do u like the end result?why did u have a filter on the idle value?
PostPosted: Wed May 28, 2008 9:53 pm
It needs air and you want it to be clean so thats why ;)
Result of the leds is ok, but there's room for improvement, there will be a 2nd protoype sometimes :P
PostPosted: Wed May 28, 2008 9:56 pm
nice job !
PostPosted: Fri May 30, 2008 1:36 am
i c ic so if i did the same it wuld benifit from it.one day i will do it and the oil catch thing i liked wat u did :D
PostPosted: Fri May 30, 2008 10:02 pm
it does not bother you if I copy your idea for the light ?
PostPosted: Sat May 31, 2008 5:30 am
nice mod! a more actual version of ZX´s tail light :)
 Post subject: Re: Cruiser's 16V part II
PostPosted: Sun Jan 18, 2009 8:24 pm
i was just wondering is ur rear bumber lowerer than a standard bumber or are they the same size?
Users browsing this forum: No registered users and 19 guests
